Generator
I have a 2009 43 Sovran with an onan generator with a raw water flow problem.
Any suggestions on where to look first?
Start at the thru-hill and move forward.
1) Take the strainer cap off then open the seacock. Do you have good flow out of the top of the strainer?
2) Take off the hose that goes from the strainer to the water pump and make sure it's clear.
3) Pull the impeller/replace if necessary.
4) If the impeller was torn up then remove the hose that goes from the pump to the heat exchanger and clear any little rubber parts.
5) Remove the end cap on the heat exchanger and remove any rubber pieces you may find.
6) With the end cap off check the tubes. Do they look blocked or plugged up? If so you may want to take it off and have it cleaned/serviced.
That should get you started Smile
You can also take a wet dry vacuum, and suck the particles back out of the heat exchanger from the direction they went in.
"tip from the Onan guy"
Brian
  BAD GENERATOR EXHAUST HOSE ALREADY ??? jcarrollgm 3 6,120 12-23-2022, 04:33 PM
Last Post: Trainman
  2003 Tiara -- Generator Question sallykropp 2 2,762 06-09-2022, 11:51 AM
Last Post: neto
  Generator fuel supply and unnecessary auto-off robin.joshua 2 2,270 05-14-2022, 09:07 PM
  Generator Sound/Vibration Isolators MC1600 0 1,411 11-15-2021, 12:14 PM
Last Post: MC1600
  generator question matatui 0 1,665 12-20-2020, 02:40 PM
Last Post: matatui
