RAW WATER WASHDOWN
went to turn on raw water washdown for the first time this season, hit the power , heard the pump turn on, went to the hose and nothing came out?? turned of switch under the stairs, tried a couple of minutes later and when i turned switch back on i did not hear it go back on and still no water??? have a 2003 42 open tiara?? does it need to be primed?? and how do you do that??? or maybee the valve is turned off??? dont know why i dont hear the pump kick back on though???? thank you....
No sure on the 42 WRT to priming as my 38 has a raw water pump but its located below the water line and doesn't require priming... Check to make sure the through Hull valve is open. I also have 2 switches, the first under the stairs on the main 12v power panel. A 2nd is in the cockpit that turns the pump on itself when pressure drops below ~40psi. Both need to be on for the pump to work... Internal to the pump, assuming it is the same or similar to mine, is a pressure switch which opens once pressure reaches pump pressure (~40psi). The pressure switch on mine stuck in the "OFF" state and prevented the pump from coming on.. I tapped the top of the switch and it stated to work... Yours may be stuck as well.. M2C
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,844 05-12-2026, 10:18 AM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 905 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,961 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 585 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 701 11-21-2025, 05:53 PM
Last Post: lenoah
