Tough to access raw water seacocks for engines
I have a 2005 32ft Express with twin 310hp Volvo Penta diesel engines; as I am very satisfied with Tiaras design I do have one issue.
The raw water seacocks for the engines are very difficult to reach with a very small area to maneuver conventional tools. In an emergency situation almost impossible !  Has anybody ever designed a tool for this or any other solution?? thx Jim
I once had a boat where they drilled a hole in the top of the seacock valve handle, had a 1/4" rod bent 90 degrees at the base and inserted into the hole with a retaining nut. Had a bracket mounted on the stringer with a 1/4" hole that the rod went through to give top support and a tee handle on the top of the rod. Worked great.
I've considered some kind of marker rods for my boat so if my er is flooded I know where to locate all the seacocks. If I can find them I'll get them closed. Be interested to hear of any other owners who have considered or designed something.
Thanks JC; Will see if thats a possible solution!
On my 29 Coronet, I cut some short sections of PVC pipe to give more leverage to the levers & make them easier to grab. I still have to jam my arm between the exhaust hoses & the edge of the fiberglas, but it helps!
my port trim tab seems to function slower than my starboard side?  pretty sure they are electric as I did not see any hydraulic fluid reservoirs in the stern?
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,772 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,898 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 545 02-15-2026, 05:34 AM
Last Post: maxcav
  [Tiara Open] Access cover to sliding door on 43 open MariTime2 0 1,034 12-14-2025, 05:34 PM
Last Post: MariTime2
  Water if forward bilge after rain lenoah 0 663 11-21-2025, 05:53 PM
Last Post: lenoah
Users browsing this thread: 7 Guest(s)
