3800 open batteries
What kind, how many, & how are the batteries wired on a 38 open?
8D, 4D or Group ??
Thanks,
Andy
On my 2003 38 Open there are 6 group 31 Gel batteries. 3 are house batteries and 3 are engine batteries. Each group of 3 are wired in parallel to each other providing 12 vdc to the system.
ReelMagic,
Where are your batteries located?
So, 1 bank of 3 starts port, starboard engine & generator and the other bank of 3 is for house?
Will the house bank power the boat all day (8hrs) if hanging on the hook (fridge, electronics, stereo & other minor 12vdc loads)?
Thanks, Andy
Yes on the configuration. 3 for main engines + Generator. 3 for house needs. We've been on the hook for more than 8hrs running all 12 vdc stuff including fridge, electronics, stereo, etc.
Thanks so much from Suffolk South Shore
We are looking at 38 opens
Your responses have been very informative
Forgot to mention where the batteries are located.. 3 (house batteries) are on the port side between the port engine and the hull side. Relatively easy to get to. The 3 engine batteries are located under the engine room access ladder/floor. Need to lift the removable floor between the engines. As a help once in the engine room you can remove the access ladder by removing the pins at the top of the ladder....
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 1,664 07-15-2026, 08:06 AM
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,565 03-24-2026, 09:46 AM
  2001 3100 open generator runs but doesn't generate electricity lakesidevu 5 3,016 11-14-2025, 01:01 PM
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,992 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
  [Tiara Open] 1994 Tiara 31' Open Charging and Inverter problems: mholts13@yahoo.com 3 4,522 11-18-2024, 10:51 PM
Last Post: Polesetter
