Tiara Open Seat back removal
Does anyone know how to remove the long, top cushion on the L settee seat back?  Grateful for any advice.
On my 2003 38 Open the curved seat top is 2 pieces. One, the side piece, covers the top port side and the 2nd covers the piece facing aft... Both pieces are removed by opening the zipper on the bottom of the top pieces allowing access to bolts that hold the top pieces to the brackets supporting it....Your seat on the 31 may be different but assume it's somewhat the same Best I have.. M2C
Thanks, but no zippers.  Appears to be some kind of bracket, based on very limited view from the edge.
If I remember correct you will have to go under the seat inside the hatches and unbolt the bottom cushion first. Then you should have access to the brackets holding the back down.
  Tiara 40 Express 2003 - Removal of Cleat saywhen 2 490 11-14-2026, 05:25 PM
  [Tiara Open] Cockpit bolster removal Rick B 0 133 11-14-2026, 12:15 PM
  2001 38’ Open interior table base removal twilson0929 3 1,032 07-07-2026, 08:13 AM
  [Tiara Open] 1989 3100 Open Wiper Arm Removal mmcintee1985@gmail.com 10 3,714 11-24-2025, 09:21 PM
  [Tiara Open] Glass Removal plagasse 2 1,142 11-15-2025, 08:53 PM
