steering 2006 Sovran 3600
it seems it might be a little sluggish.  Where to start first?  Fluid in the little fill hole? What kind?  Seastar??  TIA.
Yes seastar fluid some use atf in a pinch. top it off and spin the wheel lock to lock several times top off again.
Check the rudder tie bar as well. Heim joints/ rod ends can loosen up resulting in loss of responsiveness and trouble holding a straight course.
(11-12-2019, 09:50 PM)jclark003 Wrote: Check the rudder tie bar as well. Heim joints/ rod ends can loosen up resulting in loss of responsiveness and trouble holding a straight course.
is there anything in/on the Heim joints I should know?  I see some have a set screw you loosing before tighten the nut, will the Tiara be like that?  is there a grease fitting?
Thanks so much
My rod ends have no grease fittings or set screw, just a nut that locks the joint to the tie bar. There should be no play or movement of the tie bar. Stainless rod ends can be found online or thru Tiara. Tiara will also email you rudder alignment specification/diagram if you give them a call.
  3500 Sovran trimtabs drprunner 0 119 11-14-2026, 03:44 PM
Last Post: drprunner
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 590 08-31-2026, 10:34 AM
Last Post: Herrema4
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 757 08-17-2026, 05:31 PM
Last Post: Bford100
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 541 07-28-2026, 06:28 AM
Last Post: Tiara45
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,928 02-23-2026, 11:01 AM
