TV
my boat is a 2003, would like to get a new tv, is it hard getting the old one out?/ also its connected to the bose sound system, will i lose that if i get a newer flat screen??? would also like to upgrade the dvd player, will that affect the bose surround sound system???
I upgraded tv's on my last two tiaras. Wasn't a big deal to get the old tvs out and used a wall mount bracket to mount the flat planet over the cabinet opening. If I remember correctly there were some mounting screws on the underside of the cabinet that hold the tv in place.
connecting up to Bose is pretty straight forward. Audio out from tv or DVD goes to input sources for lifestyle (rca). Some of the flat panels however do not have rca audio output jacks and instead have optical audio outputs. For $15 Amazon has optical to rca converters that work perfectly. If you do this you will only need the one connection between tv and Bose. Anything showing on tv is routed out through optical to lifestyle including DVD. Hope that helps
Agree with advice you received. I am doing the same thing on our 06 sovran
Capt Brett M Sause
USCG Master Licensed Captain
443-220-4339
thank you so much for the help......
LET ME ASK YOU. once you take the tv off, can you reach behind it and reach the plug?? is the plug hard to get at??
Like anything on a boat it may be tight but you can get it
Capt Brett M Sause
443-220-4339
THANKS BRETT
Did my this past summer, the bracket was almost the same as the TV which had RCA connections so nothing else had to change
(01-06-2020, 06:20 PM)honest mark Wrote: LET ME ASK YOU. once you take the tv off, can you reach behind it and reach the plug?? is the plug hard to get at??
On my 42 Open, you can access the plug in the cabinet under the cooktop.
Are you replacing the stateroom tv as well?  If so, did you find one that fit well?  It's on my list of things to do this off season...
Max
