Fuel sending unit
Fuel gauge is not reading correctly. Upon troubleshooting I pulled the fuel sending unit from the tank. I tested it with an multimeter. The ohm readings were backwards. When float was down (empty) it read 10ohms and when it was up(full) it read 180 ohms. This totally opposite to what I expected or assume it should have read. Any thoughts?
Most marine fuel tank senders are 33-240 ohm where 240 is empty. There are senders out there that are reverse (low ohm, low tank). I think VDO has a 10/180 ohm tank sender in which the 10 is empty. They have a matching gauge for that ohm range.
All the Tiara's I have owned had WEMA 33-240 senders. might be worth pulling the sender from your other tank and checking the impedance range. Or if you can pull a part number from the gauge or the sender you may be able to lookup the range through the manufacturer.
  Looking for Help with Fuel Vent Issue - Tiara 2700 (1988) kahunamax 3 652 10-02-2026, 11:50 AM
  [Tiara Open] 93 3100 fuel tank sending unit. Joeboch348 1 725 02-18-2026, 09:15 PM
  Replacing fuel full hose 3100 Open Joeboch348 1 1,172 08-20-2025, 03:53 PM
Last Post: S4Survivor
Information 2000 express 4000 fuel system questions... bman440440 2 1,430 07-23-2025, 08:19 PM
Last Post: bman440440
  1993 Tiara Sport 220 Fuel in the Bildge (Leaking tank) bradcool 1 993 01-21-2025, 08:50 AM
