4500 Sovran Sliding Cabin Door
I have noticed my 4500 "plastic" cabin door is rubbing inside of the helm causing it to scratch.  Has anyone had this issue before, if so how do you adjust the helm to fix it?
Mine is getting bound up as well.
Something may be in track.
Mine has now fixed itself? Lol
Spray wd40 in top and bottom track
Worked great
THanks, I will give that a try but I think my issue is more of a rubbing on the fiberglass inside the helm.  Causing a scratch.
(06-17-2020, 08:14 AM)bsause Wrote: Mine has now fixed itself? Lol
Worked great
Well I’ll tel you I don’t know how but that wd40 worked for me !!!!
I spray wd40 in mine all the time to keep it sliding nice. It may fix your scratching problem because if the slides aren't working right the door will lift itself up as you slide it and that may be why it is scratching.
Not sure if WD40 is the answer as it does not contain any lubricant. Suggest you use a silicon spray of somesort... I did several years ago and so far ithas remained easy to open/close. M2C
  3500 Sovran trimtabs drprunner 0 136 11-14-2026, 03:44 PM
Last Post: drprunner
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 607 08-31-2026, 10:34 AM
Last Post: Herrema4
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 787 08-17-2026, 05:31 PM
Last Post: Bford100
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 556 07-28-2026, 06:28 AM
Last Post: Tiara45
  bathroom door handle fuzzy 2 753 07-18-2026, 05:43 PM
Last Post: fuzzy
