06-22-2020, 10:42 AM
I have a sun shade that came with the boat to cover the cockpit area. The stainless poles that came with it are bent pretty bad. I am thinking it is because the past owner was using them in the rod holders and forced them in the pretty good. I'm not sure exactly how the poles were supposed to be used. Does anyone have the sun shade for the cockpit of the Open model? Mine snaps to the front edge of the arch and has a pole in each corner and one in the middle, then it has straps on the corners that clip on to fitting installed right under the rub rail.
I need to replace the poles with something just not sure what. Has anyone else done this?
