garmin 7612
i bought      my boat used, the previous owner had 2 new garmin mfd installed in 2018, i am putting a fusion stereo on and was told make sure i have the latest garmin updates installed, how do i find out what version i have now and what is the latest update i can install? is it difficult to update? thank you
Go to the Garmin Site for the latest SW load for a 7612. I did mine recently and believe the latest is version 19.00.
https://www8.garmin.com/support/download...sp?id=8743
use this link for the Change History https://www8.garmin.com/support/ch.jsp?p...0-01306-01
To answer the question regarding difficulty. Its not.. You download the SW to a laptop, then execute the downloaded file. That will unpack the SW onto a SD card (needs to be 8GB minimum). Once on the SD card you move the card to the 7612 and turn on. It should sense the card and ask if you want to upgrade. If it doesn't there is a soft key to allow updating. Look at the manual for the rocedure.
There a second method which requires the Garmin Active Captain app on an IPAD/IPHONE/Smartphone. The Garmin procedure can be found on the Garmin site as well..... Your current version if found using softkeys for Software version. Should also see version when unit it first turned on.
THANK YOU VERY MUCH
  Looking to up grade to Garmin Polesetter 2 2,449 09-11-2023, 01:46 PM
Last Post: Polesetter
  Garmin Radar firstlight 1 2,299 06-28-2023, 12:57 PM
  garmin autopilot honest mark 11 13,935 01-24-2021, 02:35 PM
  [Tiara Sovran] Garmin Auto Pilot Issue DavidM 1 2,240 10-05-2020, 10:19 AM
Last Post: Misdirection
  Raymarine or Garmin?? RCKLAW 6 7,116 06-29-2020, 02:54 PM
Last Post: bsause
