Mystery toggle switch - 12 volt panel
Have learned a ton on this forum and appreciate the insight of the group -
Does anyone recognize the toggle switch in the attached picture?
Located on the 12 volt panel in the engine room of our 1995 4000 Express -
Thanks,
Brad
Definitely looks like an owner add on. Turn off most everything and see if it turns on anything. Or conversely turn on everything and see what it turns off. Worse case pull the panel cover and start tracing wires.
(08-19-2020, 05:23 AM)Sans Peur Wrote: Definitely looks like an owner add on. Turn off most everything and see if it turns on anything. Or conversely turn on everything and see what it turns off. Worse case pull the panel cover and start tracing wires.
Thanks Sans Peur, will do.  Would you expect the emergency battery interconnect to also be on the 12 volt panel?  My manual shows it there in a diagram but noticed the boat has a different 12 volt panel than the manual.
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,736 11-07-2025, 02:50 PM
  Main Panel Switch needed or 1997 40 mid cabin express Salty0ne 0 878 03-28-2025, 09:44 PM
Last Post: Salty0ne
  Electric Breaker panel Jbuchsdvm 5 5,129 10-21-2024, 10:08 AM
  Nav/anchor Light Switch Joeboch348 5 3,342 06-29-2024, 09:55 AM
Last Post: roboh20
  [Tiara Open] Switch for Lights in steps on 2007 3600 Ope Roweje 0 1,030 06-15-2024, 07:50 PM
