Battery charger location ?
Recently purchased a 1999 3500 open and have yet to locate the battery charger . Looked under v berth, stairs, engine room , under seats ,
    Will be looking again today , trying to trace wiring .
    I will have a good laugh when I finally locate it
Not sure if your charger is mounted in the same place as mine on a 2003 38 Open but here's where mine is. Mine is behind the settee backrest cushion/wall on the starboard side mounted to the engine room bulkhead. Remove the settee backrest and look for a removable/hinged door on the wall. Open/remove if needed and you will find the charger, at least that is where mine is mounted.... Good luck
Thank you , I will definitely check that out later today
ReelMagic.   Thanks for that information , it was 100 % correct.    Located the charger, hot water heater and additional wiring, and important water lines .
     Thanks , that was great info
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 551 07-28-2026, 06:28 AM
Last Post: Tiara45
  [Tiara Open] C-Charles Charger Series 5000 failed ReelMagic 3 1,144 10-27-2025, 09:51 AM
  Tiara Express Battery Charger Replacement Svdb12@chartermi.net 0 787 09-07-2025, 11:19 AM
  [Tiara Open] GFCI Location HIGH SPIRTED 0 600 07-11-2025, 11:16 AM
Last Post: HIGH SPIRTED
  original tiara battery charger drifter 1 903 07-09-2025, 10:22 AM
