1994 3100 Open Keel Question
Hello, I have a new to me 1994 3100 Open. I pulled it out and noticed this notched area of the keel that looks like a large transducer. The normal transducer/fairing housing is located near it but I'm curious to see if anyone knows what the heck this is?
.pdf   3011 Keel.pdf (Size: 482.97 KB / Downloads: 52)
Wow - can't say I have ever seen one of those.
I have a '95 3100 Open & don't have that detail on my keel.  Near you in Mastic Beach if you have other questions.
I have a (new to me) 94 3100 open.  Prior owner created a drain plug in that vicinity - something he had done to other boats he owned - because he says that is where the water pooled.  Was not easy to see because it was forward of the forward bilge pump.  The plug from the underside did not look like your photo, but wondering if someone did something similar on your vessel?    I have since removed and glassed over his plug (and easily get water out with a shop vac during winter lay-up).
I have a (new to me) 94 3100 open.  Prior owner created a drain plug in that vicinity - something he had done to other boats he owned - because he says that is where the water pooled.  Was not easy to see because it was forward of the forward bilge pump.  The plug from the underside does not look like your photo, but wondering if someone did something similar on your vessel?    I have since removed and glassed over his plug (and easily get water out with a shop vac during winter lay-up).
relatively new to me: 1994 Tiara 3100 Open 454 TBI Crusaders
More recent home port is upper Hudson river with our Tiara (closer to home)
Strange. Wild guess but maybe the keel was modified with a removable section to sit on a trailer? Maybe to accommodate the axle or cross member?
Possible previous damage and a poor repair?
(09-17-2020, 10:17 AM)reeltimebrad Wrote: Possible previous damage and a poor repair?
No. It actually looks like a transducer housing. It has the shape of a fairing block but I've never seen something like that
How about a keel cooler for a generator? Can you access the inside of the hull in that area to see if there are hoses for a cooler or wires for a transducer?
(09-23-2020, 07:30 AM)reeltimebrad Wrote: How about a keel cooler for a generator? Can you access the inside of the hull in that area to see if there are hoses for a cooler or wires for a transducer?
Hmmm. I'll dig around and see what I can find
  3500 Open deck lift piston drmiagi11 6 1,305 11-20-2026, 10:03 AM
  38 - 43' Tiara Open Comparision ClayPlatt 8 8,929 10-27-2026, 02:44 PM
Last Post: tk17
  2001 3500 open, diesel exhaust flanges? North Star 4 1,690 02-24-2026, 08:55 AM
Last Post: North Star
  1989 33' Tiara Open - Bedding Question jgaudet2 2 2,355 12-21-2025, 10:02 AM
Last Post: jgaudet2
  2003 3100 Open cabin privacy curtain. Hilary 3 3,052 12-02-2025, 02:13 PM
Last Post: E-MAN
