Threads: 14
0
Home Port: San Carlos Mexico
Vessel Info: 2001 3500 OPEN
Cummins 370 Diamonds
Has anybody removed the outside windshield frame to send out to have powder coated ?
Chuck
Threads: 9
4
Home Port: Daytona Beach, FL
Vessel Info: 2000 Tiara 3500 Open
Cummins 6bta -370
I have not BUT be careful with this project. Fasteners they used were stainless steel and the bolting surface is aluminum and several people have told me they don't come off easily or at all. Plus, realignment is very very very difficult to impossible to do once removed. I was told if you want to redo just tape off, strip, and paint using awl grip or equivalent. BUT...YMMV.
Threads: 3
20
Home Port: Lake Michigan
Most Tiara opens of that vintage have a windshield frame that as mentioned should never be removed, and caps which are the painted outside facing trim pieces screwed into the frame. The caps can be removed but must be done carefully as Tiara no longer provides spare parts. I removed and painted the caps from my 43 Open (same year). They came off with no problems other than two screws that needed a little heat to help them along . The real challenge was the cleanup and prep work. Lots of sealant, butyl tape, seals, etc that took a while to clean out. Otherwise it wasn't a terrible job but did take quite a while.
masking and painting will probably take less time and will be cheaper. taking the caps off provides the opportunity to reseal everything. Not sure which path I would take if I were doing it all over again.
Tiara has a service bulletin available that provides detailed instructions, part numbers for the seals, hints to make the job a little easier and paint codes. Probably worth dropping them a note and reviewing it before starting anything. M2C
Threads: 14
0
The caps was what I was talking about, but they are not leaking except for the center vent which I can deal with. I think I will clean them up and paint them in place with awlgrip.
Thanks for the info.
Chuck
Chuck
Threads: 9
4
Cummins 6bta -370
I have that windshield information from Tiara, if you provide your email I can send that over to you.
Threads: 14
0
Thanks Tom I sent you a pm
Chuck
Threads: 3
1
Vessel Info: 36 Open Hardtop, 52 Express Hardtop
I have removed and powder coated the frames. Use piano wire to cut though the adhesive tape and caulk. Otherwise you will bend the frames removing them.
Threads: 3
0
Home Port: Detroit yacht club
Vessel Info: 1999 35 open
Twin 454 crusaders, mpi
I’ve been touching up with white rust oleum. Does job, at some point I’m going to have professionally painted. But not going to remove.
ISBIB
Threads: 45
2
Home Port: Long Island Sound
Vessel Info: 3100 Open, 2002 Model Year, 8.1L Crusaders
Many of the Tiaras I am familiar with in my area that had the window frames done all painted them while on boat and did not remove.
