Tiara Open No Indicator Lights on AC Section of Breaker Panel
2003 Open I just purchased has no indicator lights on the AC side of the panel.  AC is working fine, just no lights.  Is there a common ground or something else I should be looking at.  There is a switch to turn the DC indicator lights on/off.  It works.  Thoughts???
Not sure about yours, but my 99 4000 has a switch on the breaker panel labeled “Panel Lights.”
I had the same problem one day. DC worked but no indicators. Drove me up the wall!
(11-15-2020, 08:13 AM)It's A Need Wrote: 2003 Open I just purchased has no indicator lights on the AC side of the panel.  AC is working fine, just no lights.  Is there a common ground or something else I should be looking at.  There is a switch to turn the DC indicator lights on/off.  It works.  Thoughts???
Most likely a ground issue on the panel , the lights get connected at the breaker and use a common ground to there respective system .
any work done should be done with the a/c and the dc powered down . use a test meter and check for resistance to ground .
You should not have any resistance . if so clean the grounds and reconnect . If no continuity at all  look for a broken wire.
Hope that helps . These are from my 1989 Tiara , had to replace all of the signal lamps on the 12 volt side as they were burnt out.
changed 2 breakers and added a new one at the same time.
All of the replaced lamps were changed to LEDS.
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 1,632 07-15-2026, 08:06 AM
  DC Panel Volt/Amp Seclector Switch Replacement Peave 4 1,745 11-07-2025, 02:50 PM
  Main Panel Switch needed or 1997 40 mid cabin express Salty0ne 0 887 03-28-2025, 09:44 PM
Last Post: Salty0ne
  Tiara 3600 Courtesy Lights No Longer Available Roweje 0 1,125 11-10-2024, 09:17 PM
  Electric Breaker panel Jbuchsdvm 5 5,136 10-21-2024, 10:08 AM
