Where to install Generator on 3100
I am looking to install a generator on my 2001 3100 and I am wondering if anyone knows where in the engine room does this get installed?
I installed a Kohler 5ECD in my 2001. It was pre wired from Tiara which made it not so bad. Tiara was very helpful with any questions and also providing the parts (breaker and slide lockouts for the panel.
It's installed between the engines towards the aft section. I could send you pics if you like.
Jeff
The factory offered a Westerbeke 5.0KW Generator as an option (gas or diesel depending on engines). It was installed center aft between the engines mounted on a support board attached between the stringers. Engine mounted towards the bow and power generation unit mounted towards the stern. If you do install the generator there, make sure you install Spray shields over the shaft logs. Dripless shaft logs do sling a fine mist of saltwater where the seal faces come together and this would line up perfectly with the generator. The spray shields will keep your generator from becoming a ball of rust in the future.
Good Luck!
Thank you a picture would be great
On my 1994 31 it was already done when i purchases it.  They removed the fishbox and put it in there.  Kinda tight between the engines i would think.
  [Tiara Open] 93 3100 fuel tank sending unit. Joeboch348 1 711 02-18-2026, 09:15 PM
  [Tiara Open] 1989 3100 Open Wiper Arm Removal mmcintee1985@gmail.com 10 3,639 11-24-2025, 09:21 PM
  C44 generator access for service Herbieville 0 576 10-06-2025, 06:16 AM
Last Post: Herbieville
  [Tiara Open] Need Source for Scuppers, 1995 3100 E-MAN 2 1,056 09-02-2025, 10:31 PM
Last Post: E-MAN
  2001 Tiara 3100 Open wipers IrvingVet 4 5,977 08-23-2025, 01:32 PM
Last Post: nylakeshome
