prop shafts
i noticed on one of my prop shaft ZINC it was quite a bit lower down (closer to prop) than my other one was? is this a problem? should they be the same?? is it as easy as putting them in the same place on each shaft and tightening them? do they need to be balanced? thank you guys...
I wouldn’t sweat it. In terms of “balancing” they’re not going to make that big a difference. You just want to be sure the one closest to the strut is at least a hand width away to ensure adequate water flow to the cutlass bearing.
  2003 Tiara 31 Open w/Cummins 6BTA 5.9 330HP Prop size alhalpern 1 1,960 06-29-2022, 06:29 PM
Last Post: Misdirection
  Prop Removal Questions - Harmonic Prop Remover ardoski14 2 3,181 06-03-2021, 06:40 AM
Last Post: reeltimebrad
  [Tiara Open] Prop options for 2001 Tiara Open (Gas) IrvingVet 3 5,315 05-09-2019, 08:50 PM
Last Post: Lured Away
  prop pocket plates justrollin 6 10,643 05-30-2018, 02:18 PM
Last Post: wasitim
  I have to take off my prop,what size nut is on the 2" prop shaft of 2006 3600 sovran? sluggo 3 5,766 07-23-2017, 10:36 AM
Last Post: Uhehner
