Fresh Water Leak near water tank
Hello, we own a 2001 35 tiara express which seems to be loosing water from the area where the fresh water tank is located. The tanks get completely empty. It is not in any faucet or plumbing after the pump, because the pump never turns on to rebuild pressure.  In the area where our fresh water tank is at we see a leak but we can't figure out if it is from the tank or the hose or if it just running water that is coming from another place.  When we empty the bilges most of the water comes out of the forward bilge.
Has anyone attempted to change the hoses and fittings in this area without cutting the floor? It is such a tight space, I do not see how can it be done. Any other info is appreciated.
Here is a video of what we are seeing in our boat:   https://www.youtube.com/watch?v=LcPngucCty8
Is that the stock water tank in the picture that came with the boat?  It looks like it is aluminum.  Our freshwater tank on my 35 Open appears to be plastic.
There is a drain plug on the front of my freshwater tank that empties into the bilge, perhaps yours came out such that the tank is draining directly into the bilge as soon as it is filled.
I don't recall if the hoses that lead from the tank to pump are side mounted near the bottom of the tank or pump mounted.  If they are top mounted, it is unlikely that they are causing the leak since there likely is no water in the lines since the pump is not running to withdraw fluid from the tank.
-M1
  Windshield Leak tip TIARACRREP 35 42,750 09-23-2026, 11:53 AM
  [Tiara Open] Hard To Locate Leak nylakeshome 0 459 09-13-2026, 12:17 PM
Last Post: nylakeshome
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,821 05-12-2026, 10:18 AM
  [Tiara Open] 2001 3800 Open Holding Tank cap that hold sensor and washdown twilson0929 0 894 05-12-2026, 10:18 AM
