Tiara Open 2004 Open 32
Need some assitance.  I have twin Crusader 8.1L engines and they run great!  Problem is that the port Engine voltage meter shows 12v and not the 13.5 - 14 that it should.  I took the original alternator off and it was burnt up inside so I replaced it.  The new alternator showed 14v for the first hour or so and now back down to 12v.  Is there an isolator on the 32 open that I should be looking for or has anyone else had this problem before?  everything runs great it just makes me a little uneasy with the improper voltage.  Thoughts are welcome and thank you.
Karl
I heard of similar issues with the 8.1s.  At least on my (previous) 8.1s, the alternators have external voltage regulators (Charles C-Charger double alternator regulator) that controls the output to the battery banks.  I watched some videos of another Tiara Open with 8.1s running and the voltage gauges were as you described (low voltage on one or both banks).  I don't know if the gauges monitor alternator output or battery charge level.
While you are underway (obviously with someone at the helm), check the voltage readings on both battery banks (house/engine) on the DC panel inside the cabin.  You will probably notice that they indicate that the proper charger voltage is being supplied, even though the gauges on the helm indicate otherwise.  In my experience, the charge didn't kick in until around 1K rpms.
Also, not sure if you have gel or lead acid batteries, but you may want to check the Charles C-Chargers to make sure that the dip switches are set to the proper battery type, which changes the charge profiles.
Best of luck!
M1
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 1,664 07-15-2026, 08:06 AM
  1988 3300 Open - Voltage drop when lowering engine hatch or honking horn Pluto 3 1,565 03-24-2026, 09:46 AM
  2001 3100 open generator runs but doesn't generate electricity lakesidevu 5 3,016 11-14-2025, 01:01 PM
  [Tiara Open] 2005 TIARA 2900 OPEN DC ELECTRICAL SCHEMATIC COPY HIGH SPIRTED 2 2,992 07-05-2025, 12:54 PM
Last Post: HIGH SPIRTED
  [Tiara Open] 1994 Tiara 31' Open Charging and Inverter problems: mholts13@yahoo.com 3 4,520 11-18-2024, 10:51 PM
Last Post: Polesetter
