Audio Amplifier location for upper cockpit speakers
My 2005 32 Open has two audio speakers in the cabin, four audio speakers in the upper cockpit and a subwoofer in the lower cockpit.  The system is the original Clarion package.  My four upper cockpit speakers no longer work at all.  I am not able to locate the amplifier which powers those four speakers.  Can someone help me locate the amplifier which powers the four upper cockpit speakers?
The power amp in my 04 35 open is under the dinette seat against the rear bulkhead.
On my 2003 38 Open the Amp is located behind/below the power distribution panel in the dinette. Access is by removing 2 screws that hold the distribution panel in place as it is hinged to swing open for access behind the panel. Not sure if you have a similar configuration..
I completed same amplifier replacement on my 3200. Location is on stb side in front of helm. Remove teak panel above dinette seat with four screws and amplifier can be accessed.
There is an older thread if you search “3200 Open Stereo Amp Location”
Good luck.
  [Tiara Sovran] 2008 Sovran 3900 AC Raw Water Pump Relay location bbisland 1 2,398 12-21-2021, 10:40 AM
Last Post: Skipper747
  [Tiara Open] Compass Location becnme 2 2,435 03-02-2021, 01:29 PM
Last Post: becnme
  88 3100 access to AC ductwork and speakers behind settee SlowPoke 3 3,830 02-08-2021, 08:34 PM
Last Post: Jimmy
  31 Open Cockpit Seating Jon H 2 2,814 01-28-2021, 08:26 AM
Last Post: Matta0413
  Cockpit Steps duchess 0 1,223 11-09-2020, 10:39 AM
Last Post: duchess
