4000 express fresh water pump
My new to me has two fresh water pumps. Did it come from factory that way.  Has two circuit breakers on the breaker panel. The pumps are not same. Appreciate help. Jack
As far as I know the 2 pumps are there to minimize water pulsing when more than one faucet is being used.. each have a different capacity. This has been a subject of several posts on the forum.. I use both when using the internal water tank....M2C
(08-09-2021, 07:05 PM)ReelMagic Wrote: As far as I know the 2 pumps are there to minimize water pulsing when more than one faucet is being used.. each have a different capacity. This has been a subject of several posts on the forum.. I use both when using the internal water tank....M2C
The next time you are at your boat could you send me a pic of your pump set up. Previous owner sort of messed it up. Thanks. Jack
This picture is from another 38 Open but its the same as mine. Let me know if its what you wanted...
(08-10-2021, 07:16 AM)ReelMagic Wrote: This picture is from another 38 Open but its the same as mine. Let me know if its what you wanted...
Thanks for pic..I still don’t under stand where the pipes are comping from and going to.  Attached is my pump layout and it is noisy as hell.
I've taken your picture and marked it as best as I can.
.pdf   Presentation 2.pdf (Size: 184.29 KB / Downloads: 24)
(08-10-2021, 08:34 AM)ReelMagic Wrote: I've taken your picture and marked it as best as I can.
Thank you. Mine looks like a rats nest. Don’t know how to thank you.  Jack
I have been wondering the same thing. Mine is a bit different. Both are fed from the freshwater tank and both will feed all the taps. The biggest difference is the pump sizes on mine. The larger of the 2 pumps is actually connected to an accumulator tank. The smaller 2nd pump never kicks on unless the "main pump" is switched off. I chocked it up to the smaller second pump as being a back up.
What’s wrong with tearing both pumps out and putting in a large surge tank and A strong fresh water pump. Simple is good. Jack
  1994 40 Express fresh water tank leaking papa1534 5 2,150 10-12-2026, 07:52 AM
  [Tiara Open] 3800 Open Fresh Water Tank Mineral Deposits twilson0929 6 2,933 12-12-2023, 03:52 PM
  Water Pumps bcgettel@gmail.com 3 2,170 08-21-2023, 04:18 PM
Last Post: MC1600
  3500 Express 97 jeancmartinet 3 5,678 09-11-2022, 03:18 PM
Last Post: MC1600
  PITA Bilge Pump Bracket Newbie7749 0 1,378 09-08-2022, 03:07 PM
Last Post: Newbie7749
