Threads: 1
0
Home Port: Huntington
Vessel Info: 2006 39 Convertible
Volvo D9 575hp
New to me 06 39 convertible, 2 fresh water pump breakers, when running shower or cockpit wash downswater
breaker pops when both breakers are on. Replaced shower box float and flo jet pump, also get a pulsing on all lights on boat when running galley sink? Any suggestions on what is going on? Thanks for any help, this is driving me nuts! Cristina
Threads: 14
11
Home Port: Kings Park, NY
Sounds like the fresh water pump or pumps are drawing to much current.... May need a rebuild/replace.. Just a guess
Threads: 1
1
Home Port: Fort Lauderdale FL
Vessel Info: 2006, with Cummins QSC 8.3 common rail
Having the same problem except the breakers don’t trip. I just have to rest them. I’ve replaced all six batteries and one alternator. Can’t figure out why resetting un tripped breakers will fix the problem. Once the water is running the pumps just keep it coming. On shore power the fresh water will just stop working. I reset the breakers and alls well. Was underway for several hours fishing and it took about 20 minutes of resetting to get the system on again. The pump felt warm to the touch even though it wasn’t running. Maybe an internal thermal switch on the pump? Any suggestions?
