Water pump retro fit kit for the 8..1
Recently looking for the 8.1 water pump retro fit kits / 2004 and later but it seems crusader has discontinued them.
Any experiences with the retro fit kit?
What about building the kit from separate part numbers?
Thanks.
David
When I purchased my 2003 35 Open w/8.1s (recently sold), I had the dealership change the cam shaft mounted pumps to the pulley driven pumps using the conversion kits, as the old cam shaft mounted pumps weeped.
I'm fairly certain that all of the parts for the conversion kit are available individually as the 2005+ 8.1s had the pulley driven raw water pumps standard.  The conversion kit just gave you the parts to change the 2001-2004 8.1 raw water pumps to the 2005+ raw water pumps.
These are the part numbers from the parts manual, but you should verify this first.
RA057035 Raw water pump assembly
R065056 Pulley, raw water pump
93940000 Lockwasher, bracket attaching
98443030 Bolt, raw water pump mounting
92934000 Washer, pulley mounting
93934000 Lockwasher, pulley mounting
99335016 Bolt, pulley pulley attaching
R066024A Belt, accessory drive
18402 Hose, raw water pump to transmission cooler
Good luck!
M1
Thanks M-1
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,847 05-12-2026, 10:18 AM
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,965 02-23-2026, 11:01 AM
  Water alarm in the diesel filters maxcav 0 586 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 702 11-21-2025, 05:53 PM
Last Post: lenoah
  Keel bilge pump runs on 52 Sovran Salon during trips Knot On Call 9 3,194 08-21-2025, 08:28 PM
