Tiara Open How can I repair crack in bottom of holding tank without removing tank?
Question
I recently noticed a leak coming from the holding tank. After further observation, I can see the leak is in the middle at the bottom of the holding tank. Is there a way I can fix this without removing the tank?
You might be able to cut an access hole in the top, get down in there and clean the bottom and weld or epoxy a plate over the defect. That is providing the leak isn’t where a baffle meets and providing you have access to the tank top and may only be a temporary fix. Good luck
What model boat?
  1997 4000 Express - Holding Tank Replacement jennyJ 9 5,274 05-26-2026, 07:27 AM
Last Post: frank.koetter
  Water tank level sensors Final Pursuit 4 2,533 10-09-2025, 06:37 AM
  Holding tank collapsing fix giff1 5 3,236 10-18-2024, 06:00 AM
Last Post: egstasea
  2018 38LS Black water tank location Scottbee 1 1,859 03-11-2024, 10:27 PM
Last Post: Scottbee
  crack in mid bildge honest mark 3 2,940 01-27-2022, 02:21 PM
Last Post: neto
