No alarm beep when turning ignition key 454 crusader gas engine
I am have an intermittent issue.
When I turn my starboard key … no beep.
I tightened the wires on oil sending unit.
Replaced oil pressure alarm..
It worked for awhile..
Now I found I have to unplug a connection on the starboard side front of my engine. Not sure what this does.. but it gets the boat started.
Usually after a few days of non use or heavy rain. (Just my hopeful observation)
Any ideas of what could be happening?
I am assuming a loose connection or something is being re-set when I unplug?
First thing I would do is remove, clean, and reinstall the ground to that motor. If it looks questionable in any way, just replace it.
Closing out this thread.
After tracing the wire and replacing all connections.. I traced back to the relay.
It is on top on the engine in the breaker box.
Cleaned connections and replaced the relay.
It seems the relay was sticking.
Easy DIY repair..
all is good again
  [Tiara Sovran] Hot Engine Room Nelsond 0 114 11-04-2026, 11:36 AM
  Tiara 4000 Express Cummins 6CTA 8.3 In-Frame Engine Rebuild Jack Aperio 3 3,089 05-23-2026, 03:27 PM
Last Post: Capt. Paul
  2007 3600 Open QSB 5.9 380 hp Propeller and Engine Performance Test today Roweje 1 1,438 08-06-2025, 09:41 AM
Last Post: Sapphire
  Cummins 6CTA 8.3 Engine Rebuild - Additional Photos Jack Aperio 3 2,587 07-08-2025, 09:41 AM
  Engine Surveyor czarcone 2 2,697 10-13-2023, 05:27 AM
Last Post: czarcone
