Assessing Year End MPG and GPH
I keep copious records for any number of reasons.  One of them is so I can consider the overall health of my motors through fuel burn numbers.  I have some interesting numbers this year and am curious what you all think...
Boat: '99 4000 Express with CAT 3208's (435hp)
Cruise:  She seems most comfortable at 2300RPM which consistently gives me 19-20kts.  According to the performance report for this boat, I should be a hair faster (23kts) at that RPM, but have always written it off to age of the boat, stuff, varying fuel/water levels, etc.
MPG/GPH:  Interestingly, for the RPM/speed I mentioned above, my average GPH for the season (21.5) is a bit less than what the performance report says it should be (29.6).  I would consider this good. But my average MPG for the season (0.56) is also less than what the performance report says it should be (0.89).
Thoughts?  I would expect MPG and GPH to be high or low together, not spread in different directions.  Curious what you all think.
How much junk you got on the boat. When I sold my 41 Open I was unloading all my gear and realized I had a ton of stuff that I had just accumulated over time. That will definately slow a boat down and make the engines work harder.
Does it get to full RPM? Props may be a little off as well.
Props were just redone and she does hit 2850. I also posted this on boatdiesel.com and they seem to think I’m running a hair slow. At 2300rpm I’m using a lot of trim tab, so maybe if I bump it up to 2400, those numbers will come to the middle?
I was paranoid about overworking the engines, but I guess the difference between 2300 and 2400 is negligible.
My 41 Open had the same engines and seemed to have the same numbers as yours. 20 mph cruise and averaging around 0.5mpg
What RPM would you typically run?
I was doing the same. 2300 to 2350 was my cruise.
