31 Open Cockpit table
OK Tiaradom!
Has anyone out there build a table to fit in the seatee area adjacent to the helm? Winter is coming and I've been thinking of this project for awhile. It obviously need to be removable. The seats are elevated so no matter the configuration, it's a custom height post and requires lateral and fore-aft reinforcement if anyone bumps it underway (for sure will happen). I've contemplated a typical post / recessed base with a very stiff (removable probably custom) bracket about the height of the seam from base to the seat vinyl. I know that Peko or someone make a "v" bracket that is removable table post, but I don't think it has the lateral stiffness and there isn't a good mounting location with the access door to the storage.
Thoughts and or pics would be welcome!
(10-17-2014, 05:03 PM)together.Dakota773 Wrote: OK Tiaradom!
I purchased a Eude table from Defender, added the drink holders and used a standard recessed post assembly on the deck. I secured a U bold around the post thru the foot rest (it does limit full door opening) but when in use it stable enough for normal eating, table work etc.  http://www.defender.com/product.jsp?path...id=2307607  As you noted post was custom length. just welded 2 pieces to make needed length.
  [Tiara Open] Cabin Laminate Repair- 3300 Open Boatworks 1 107 11-17-2026, 03:49 PM
Last Post: joshuawhite
  Adding a generator to a 3500 open Simpleg1 1 2,027 09-09-2026, 06:53 PM
Last Post: penneyma
  [Tiara Open] Extend Swim Platform 1988 36 Open tomconroy 4 5,188 02-07-2026, 12:15 PM
Last Post: jgaudet2
  Adding a Live / Bait Well to my 3200 Open ove.schuett@comcast.net 1 1,593 07-07-2025, 06:55 PM
Last Post: Woodworker2001
  [Tiara Open] Larger and Smart TV for 2006 3600 Open Trainman 1 2,343 06-18-2025, 03:20 AM
