Tiara Open Manual Mode For Vacu-flush
Is there a way to operate a vacu-flush toilet manually?  Pump motor is fried. Waiting on replacement. Bowl is full
Do you have an overboard discharge pump? Usually they are the same pump and you could swap them out. Most people don't use that pump much anyway.
There is an overboard discharge but it's powered by the same pump.
Usually the vac unit pump and motor is seperate from the overboard discharge pump and motor..... Depending on the motor, it might be interchangeable. Is it the pump or the motor that has failed on the vac side?
  Vacu flush runs intermittently rcwiegand 5 6,621 08-26-2019, 08:30 AM
Last Post: rcwiegand
  Vacu-Flush - Location of Vacuum Pump eric_nelson 5 7,477 12-31-2016, 07:35 PM
Last Post: sbw1
  Holding tank replacement and manual tgardner 3 5,035 04-12-2013, 04:58 AM
Last Post: tgardner
