GFIC Reset Location 2020 53 Fly
Tripped using shop vac and water.  Found one reset in transom locker but it was not tripped.  Where are the others located?  Thanks
2020 53 Fly
Gulf Coast Florida
It would have to be on the same circuit as the plug you were using. Start plugging into the other sockets around and see which ones are not active. One of them will have the GFIC.
(11-19-2022, 06:19 PM)Sans Peur Wrote: It would have to be on the same circuit as the plug you were using. Start plugging into the other sockets around and see which ones are not active. One of them will have the GFIC.
Thanks, tried to locate others.  Owners manual says there are 3 "aboard" the vessel with no explanation as to where.  Looked in locations of all previous brands of boats...engine room, every outlet, heads, gally, closets, etc.  That's why I posted, the other two are in some mystery location.
2020 53 Fly
Gulf Coast Florida
Are there any other locations that aren't working? GFIC is usually on a 3 socket circuit.
(11-19-2022, 03:21 PM)Sapphire Wrote: Tripped using shop vac and water.  Found one reset in transom locker but it was not tripped.  Where are the others located?  Thanks
Presuming the Fly location is the Same as the Coupe, see below from the manual.
1.3.4
A/C and D/C Distribution Panels The A/C and D/C Distribution Panels are located under the starboard salon loveseat (Figure 1-4). Lift the inboard edge of the base seat cushion in order to raise the loveseat up. To access the distribution panels, lift the Plexiglas panel cover. NOTE: The A/C switching box, located aft of the A/C Distribution Panel, should be accessed by qualifed personnel only. Three GFCI outlets are located inboard of the A/C Distribution Panel. If a circuit is overloaded (indicated by a red light on the outlet), press the outlet’s ‘reset’ button to reset.
Thanks to all for all the suggestions, owners manual, copies etc.  The owners manual was wrong for our particular hull.  The breakers were not in the electrical distribution panel as indicated, but instead were behind the bottom drawer of the sofa end cabinet to the aft of the panel.  The drawer had to be removed to access the GFCIs.  And yes, one was tripped and all is well after resetting. Oh, and Tiara sent me the owners manual too.....I had to find this one myself.  Thanks again team.
2020 53 Fly
Gulf Coast Florida
  Inverter- How to use and location 39 Sovran August Rush 3 1,997 09-02-2025, 09:49 AM
  2006 3600 Sovran Generator Battery location Final Pursuit 0 921 08-09-2025, 07:49 AM
  2000 3500 Express Cockpit Fridge and Plug Outlet Breaker Location JMGCINCY2023 2 1,766 08-18-2024, 07:22 PM
  31 Open Horn Location Final Pursuit 0 1,227 11-14-2023, 12:29 PM
  [Tiara Open] Location of dash board fuses Hartsnet 1 1,864 06-16-2023, 01:45 PM
Last Post: Misdirection
