Tiara Sovran 2005 Sovran 3600
I’m having trouble with my shore power. My marine just put in new
Pedestals with the new gfi and I can only run one 30 amp line at a time. If I try to run both 30 amp lines it trips the breakers on the pedestal. Any ideas  on what would cause this??
Thanks, Bill
You have a neutral line crossed to a ground somewhere. Plug both lines in and turn off all breakers. Then slowly turn them back on one at a time. When you trip the GFI on the pedestal then at least you have a direction to look.
As mentioned above, either a neutral to ground, OR the neutral bus bars are crossed. The new breakers are essentially GCFI breakers and your showing an imbalance when both are connected.
  3500 Sovran trimtabs drprunner 0 95 11-14-2026, 03:44 PM
Last Post: drprunner
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 571 08-31-2026, 10:34 AM
Last Post: Herrema4
  Tiara 52 Sovran Salon Keel Question Knot On Call 2 736 08-17-2026, 05:31 PM
Last Post: Bford100
Exclamation [Tiara Sovran] Sunroof motor location on ‘13 sovran 45? Tiara45 0 520 07-28-2026, 06:28 AM
Last Post: Tiara45
  [Tiara Open] 2005 3600 Open / Bait well water deflectors KRB 3 2,898 02-23-2026, 11:01 AM
