Tiara Open Center bilge area
good afternoon, I have a 1990 Tiara 33open, love the boat, the questions I have there is a compartment in cabin floor it has 4 holes in it one on each side and hold water, the only way it drains out is a hand pump. Any thoughts why this is in this area and why does it hold water. my second I have two holes in the bottom of the stern on the outside of the hull, are these part of the limber hole system and are plugs required. Thanks in advance for you input,
As far as your mid bilge, is your ac, shower sump, or anything else draining into there that shouldn't be? My shower sump pump is located in the mid bilge and needs run when the shower is on. But make sure you don't have a leak or something else going on there.
The two holes on the stern are not part of the lumber holes. Those are all internal to the hull. The only thing I can think of is those are where the bolts to hold your stern sacrificial anode should be.
(05-21-2023, 06:12 PM)Misdirection Wrote: As far as your mid bilge, is your ac, shower sump, or anything else draining into there that shouldn't be?  My shower sump pump is located in the mid bilge and needs run when the shower is on.  But make sure you don't have a leak or something else going on there.
thank you for answer, I have ac drain to mid bilge, this one in question is about a foot from main berth i keep drained every 5 days, no way to install pump. I am having a new port engine installed this week, been using with port engine to be installed.
The AC should not drain into the mid bilge if there is not an automatic pump located in there. It needs to drain overboard or into the aft bilge where the pumps can remove the water.
  Coronet 2900 - Aft bilge pump access wham 2 2,278 02-02-2022, 03:34 AM
Last Post: wham
  98 3100 Open front bilge manual Switch? robh19 5 4,199 01-14-2022, 09:37 AM
Last Post: Matta0413
  [Tiara Sovran] San Francisco Bay Area “future” Tiara owner BayAreaCharlie 1 1,964 03-28-2021, 02:39 PM
Last Post: dbriceno
  New Member - Carolina Coast Area Pretty Work 0 1,850 11-17-2014, 09:47 AM
Last Post: Pretty Work
