Battery charger Location-1994 31 open
Hello,
Anyone have an idea where the battery charger is located on 1994 31 open? It is a professional mariner 35 amp. Also, looking for recommendations of what to replace it with.
I have a 2002 31 Open and mine is mounted to the bulkhead under the main electrical panel. I have to remove the access panel and it is right there. Mine had the original Charles charger. They don't make it anymore so I found a Victrion that had the identical foot print and same charging specifications as the original.
Thanks! I didn't see it there under the electrical panel. Going to try removing the settee seat and seeing if it's behind there
  [Tiara Open] Main DC Breaker for 1995 Tiara 36 Open petrienorris@gmail.com 2 1,620 07-15-2026, 08:06 AM
  2001 3100 open generator runs but doesn't generate electricity lakesidevu 5 2,950 11-14-2025, 01:01 PM
  Inverter- How to use and location 39 Sovran August Rush 3 1,955 09-02-2025, 09:49 AM
  2006 3600 Sovran Generator Battery location Final Pursuit 0 895 08-09-2025, 07:49 AM
