Threads: 3
0
Home Port: Long Island Sound
Vessel Info: 2002 38 Open 450 cummins
Looking for a back drop for my 2002 38 open. There is a track on the hard top that is used for the cockpit cover. Does a back drop normally come from the factory or is it a custom fit?
Threads: 14
0
Home Port: San Carlos Mexico
Vessel Info: 2001 3500 OPEN
Cummins 370 Diamonds
Any marine Upolstery shop can make you one, it’s pretty easy for them and probably cheaper than tiara, if they would do it.
Chuck
Threads: 14
11
Home Port: Kings Park, NY
I have a 2003 38 Open and the boat was ordered with both the aft curtain and the back drops. The back drops are 3 pieces each with clear glass in them. They attach to the hard top via a valance that slides into the hardtop track. The valance has 2 sets of zippers one for the aft curtain (goes port to starboard, 2 zippers) and the 2nd set that has 3 zippers that are used to zipper in each of the 3 back drop pieces.. You can actually have the aft and the back drop curtains attached to the hard top at the same time although some of the snaps on the hull are used for both the aft curtain and the back drops.. M2C
