Tiara Coronet Rudder Position
Question for the group on the proper rudder height.   The starboard rudder is positioned 3-4 inches higher than the port rudder.   Assume both should be at equal heights but not sure which is the proper height.
thinking the rudder position should be lower to get better water flow and steering but not sure.
Appreciate any input.
I would reach out to Tiara and have them send you the rudder calibration specs. That should give you the X dimension and tow specs.
Off hand I would say the port rudder dropped down and the safety pin is keeping it from falling out, something you do not want to happen. Definitely would not run the boat until you get it figured out.
  [Tiara Open] 89 3600 open rudder needs replacing BurdenLSU 0 847 12-06-2024, 11:01 AM
Last Post: BurdenLSU
  rudder extensions honest mark 2 2,108 09-09-2022, 01:09 PM
Last Post: honest mark
  2001 3500 OPEN Rudder shaft seal size Crown Royal 0 1,441 05-02-2022, 03:17 PM
Last Post: Crown Royal
  Size for 3500 express Rudder packing inside nut neto 0 1,686 09-09-2021, 12:00 PM
Last Post: neto
  [Tiara Open] 1988 33’ Open Rudder Arm Play - Remove Pin? ardoski14 1 2,487 04-19-2021, 09:53 PM
Last Post: Bice0004
