Tiara Open Vibration getting on plane and coming off plane
2004 35 Open with 8.1L Crusaders-2200 hours.   Last year, started noticing a slight vibration from 2400-2800 rpm during the process of achieving and coming off plane.  Balanced props last winter and vibration still noticed.  Engine alignments are in spec, no shaft run out, cutlass bearings look good.  Unable to determine which engine is creating the vibration.  Seems to be harmonics.  Been to two servicing marinas.  Vibration is worse with a full load of fuel, disappears with low load.  No vibration up to 2400, and no vibration while on plane to WOT.  I am the original owner and never hit anything.  Plan to pull props/shafts and have them inspected/balanced as a set and change cutlass bearings this off season.  Anyone else experience this or other suggestions?
  Where is Water Coming In? Newbie7749 3 2,670 08-07-2023, 10:07 AM
Last Post: Newbie7749
  Aft bilge running at plane holiday3900 3 5,040 08-06-2017, 01:38 PM
Last Post: holiday3900
  Leaks? Help with understanding where the water is coming from Crackofdawn 9 13,895 05-07-2017, 06:47 AM
Last Post: rose_surfer
  Generator running while on a plane Crackofdawn 11 12,250 01-28-2017, 05:55 AM
Last Post: Crackofdawn
  Vibration anthem 6 9,076 12-17-2013, 06:04 PM
Last Post: Uhehner
