2000 3500 Express Windshield Wiper Blade Replacements
The wiper blades look a bit different than what one would normally see on a vehicle.  The manual does not give a size or type.  Also, my washer fluid does work but the the manual does not say where the bottle is to fill it.  Any ideas?
Thanks, Mike
I replaced the windshield wiper blades with those manufactured by MARINCO... Seemed to be exact replacement on my 2003 38 Open. Blades are SS... My windshield washer uses water from the fresh water tank... The dashboard switch activates a solenoid allowing water from the fresh water system to spray the windshield... Is your fresh water pumps on? If so I'd guess the solenoid is not activating.. M2C
Thank you for the blade info.  The washers all work fine.  I thought they might have a separate tank somewhere.
Mike
We purchased a 2007 3600 open eight weeks ago and I had the same question. Go to IMTRA.com and call them. They walked me though getting the correct wipers after two previous attempts at other places. The fresh water is supplied from the fresh water holding tank as others have mentioned.
(08-11-2024, 07:31 PM)JMGCINCY2023 Wrote: The wiper blades look a bit different than what one would normally see on a vehicle.  The manual does not give a size or type.  Also, my washer fluid does work but the the manual does not say where the bottle is to fill it.  Any ideas?
Thanks, Mike
Commenting on this older thread since this question comes up from time-to-time.  Here are the original wiper blades installed by Tiara for my 2002 Express:
(1) Wiper Blade 18'' Blk. Item #3341960 from Global Products LLC dba Wiper Technologies
(2) Wiper Blade 20'' Blk. Item #3342900 from Global Products LLC dba Wiper Technologies
Perfect replacements (ordered from Grainger in Feb. 2026)
(1) PEAK Transport Wiper Blade, 18'', Mfr. Model TRP183
(2) PEAK Transport Wiper Blade, 20'', Mfr. Model TRP203
Cost was only $13.36 per blade  Cool
I was able to get the Peak Transport Blades. Perfect. Thank you for the info.
Mike
  3500 Sovran trimtabs drprunner 0 93 11-14-2026, 03:44 PM
Last Post: drprunner
  Windshield Leak tip TIARACRREP 35 42,423 09-23-2026, 11:53 AM
  [Tiara Sovran] Wiper Blades 3900 Sovran Euphoria38 1 571 08-31-2026, 10:34 AM
Last Post: Herrema4
  Windshield Wiper Arms and Blades Lafobrian@gmail.com 17 16,599 06-20-2026, 11:59 AM
Last Post: nylakeshome
