2006 3600 Sovran -AC water hoses
All the water hoses that feed my three AC units are showing signs of age and need to be replaced. Has anyone undertaken this project? Not sure if Tiara made replacing them something that could be accomplished later. Sometimes I have seen hoses with clamps in areas that can’t be reached and that makes this a daunting task. Any advice is appreciated.
  Mike
We bought a 2004 Sovran 5200 in 2023 with original AC as well as other hoses. I had the yard replace the hoses and clamps across both engines and mechanicals. Some of the AC hoses required getting into spaces that may require a second person to pull you out. But what sinks a boat are hoses and clamps!
  39 Sovran VacuFlush Pump Access Euphoria38 6 3,224 07-26-2026, 10:26 AM
Last Post: Euphoria38
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 943 06-20-2026, 07:16 AM
  Water tank level sensors Final Pursuit 4 2,527 10-09-2025, 06:37 AM
  Water quick connect fittings Final Pursuit 2 1,857 07-30-2025, 03:18 PM
  2900 open - a/c water pump not running North000 2 1,785 06-22-2025, 02:18 PM
