2007 Savron 390 engines
hello, I'm thinking about purchasing a 2007 savron 390. during the engine survey it was brought to my attention of a plaque attach to each engine (Volvo) stating something related to the life/replacement of each engine being 1000 hours. Current hours on each engine are 800.  can someone elaborate on what its meant by it?  I dont want to buy it if I'll need to replace or even do a major hull on the engines.  any suggestion will help me make a better choice.  furthermore, I will post a pic of the plaque as soon as the surveyor sends it to me
Thank you.
Nothing magical happens at 1,000 hours. If the engines are in good condition and have been properly maintained they will last a long time. It is typical for engines to receive a major service at around 1,000 hours. Typically referred to as '1,000 hour service', however even that is typically overdone by diesel mechanics so they can send their kids through college.
If you have questions about the engines in a boat you're considering purchasing (which you should), then you should hire a mechanic to inspect the engines and listen to his advice. This would be separate from a boat surveyor.
(10-09-2025, 01:50 PM)hiccup Wrote: Nothing magical happens at 1,000 hours.  If the engines are in good condition and have been properly maintained they will last a long time.  It is typical for engines to receive a major service at around 1,000 hours.  Typically referred to as '1,000 hour service', however even that is typically overdone by diesel mechanics so they can send their kids through college.
Thank you for the reply.  yes Im having an engine surveyor do a full survey.   ive received the maintenance records/invoices from the owner.   it looks like he spent $38k on drives replacement back in 2023.   I realize "S#@$" happens but I'm wondering what's a realistic yearly maintenance cost for this boat?   is there something with the IPS drives I should be concerned with?
IPS drives do require significantly more maintenance than straight shaft inboard engines. The yearly cost depends a great deal on how lucky you are. The most important thing is to have a competent mechanic who is familiar with the drives and can get parts that is trustworthy. The IPS drives have a lot of advantages, but if you don't have a mechanic who fits that description nearby, I would avoid them.
  [Tiara Open] Cummins 6BTA 5.9 Diamond Series Engines Fishy_Business 2 1,312 12-12-2025, 12:02 PM
Last Post: Fishy_Business
  2007 3600 Open QSB 5.9 380 hp Propeller and Engine Performance Test today Roweje 1 1,439 08-06-2025, 09:41 AM
Last Post: Sapphire
  2007 3900 Sovran Owners Manual and parts manual ccomeaux 1 2,824 10-11-2022, 01:51 PM
Last Post: Euphoria38
  [Tiara Sovran] Volvo Penta D6 435D-A engines IPS 600 Albino58 0 1,834 06-02-2022, 07:32 AM
Last Post: Albino58
  Exhaust Riser Replacement on 1996 40 Express with Cummins 6CTA engines janste2018 7 8,206 01-27-2020, 07:39 PM
