Seriously considering a '98 4000 Express Cruiser... Have some questions...
Hello to all,
This is my first post on this forum but have been looking around for a while.  We have found a local '98 that is in really good condition cosmetically and priced well.  It does have Cat 3208TA engines, and I do have some questions about them, and a bunch of other questions as well.
The boat is in great shape for its age, but I have been told that hull moisture issues can run rampant on these.  The swim platform is soft in spots, but no other soft spots that we can feel by walking around.  The broker helped the current owner find and acquire this boat a few years ago, and says that there was minor moisture issues here and there at the time, but the swim platform was soft then too.
Have any of you repaired a soft swim platform?  How would the bottom be accessed? Is the bottom cover removable or do you have to cut it away to access the bottom?
Seems like outboard sides of the motors are pretty tight to the fuel tanks.  Anybody do their own work and can you get to what needs to be done?
Aftercooler and heat exchanger service is required every couple of years and it seems really tight to work on these motors.  Anybody have an idea of what premium i should expect to pay for this?
Is the access to the engine compartment only via the lift up seat?  Does some other hatch open for better access/engine service etc?
Beyond a thorough inspection and engine survey, is there any model specific things I should look for or pay attention to in the survey?
Sorry for the long post, but looking forward to hearing from you guys and will probably have more questions as well.
Cheers!
I had a 99 for a few years.  One of my favorite boats in terms of layout and seakeeping.  BUT, very slow!  In my opinion it was under powered substantially.   That said, it handled seas like a champ.
To your questions:
1. Moisture issues are an issue for any boat.   My 4000 Express had light to moderate moisture around the windlass and some in the platform.   I simply rebed the hardware and called it a day.   The only way to access the interior to the platform would be from the underside.   I did have to do this to install a dingy davit.  I got the stringer schematics from Tiara along with some photos....they can assist if needed.   The access hole I created I ended up reglassing it, but if you cut is above the water line you could probably get away with some hatches.
The 3208's are great engines but very challenging to work on.  The starboard side is very tight to the fuel tank so doing impellers and anything on the outboard side take a lot of finagling.   Height is also an issue.  Getting the aftercoolers out was quite the chore for sure.     The Cummins is an inline engine so I imagine its easier to work on since it much narrower.   If I had to buy the boat again, I would opt for the Cummins power if possible.   The Cummins engines are substantially lighter, so the boat might be "faster" with Cummins Power.
The entire cockpit sole lifts up but only enough to do some basic work.  Most access if via the day hatch.   If major work is needed, you will need to remove the sole.
On the aftercoolers...its a must to do...it will cost a lot if you replace them.  Remove, clean and pressure test.   I think it took me about 15 hours total to do the job.  I had never done it before so I was probably on the slow side.
Aside from the usual survey and inspection issues that could crop up on a 25 plus year old boat be sure to check the holding tank for leaks.  There are lots of them that leak and its a nightmare to fix.  Same with fresh water tanks.  Personally I would insist that both are full of water with dye at survey.  You will want the boat as heavy as possible anyways for seatrial.
Also be sure your hydraulic tables and trunk are working.  Parts are probably scarce for that system.
Great boat, just do your due diligence.
(08-04-2026, 03:53 PM)amajamar Wrote: Hello to all,
Cheers!
Thanks for your reply!
We did end up passing on this one, as several things we discovered during survey were concerning to the point of not moving forward with purchase.  We did sea trial the boat though, and I thought it handled well and was not much slower than my current boats cruising speed, so that was not an issue for us.
Unfortunately, this boat, due to its age had not had much "preventive" maintenance done over time, which left significant things to be done.  All holding tank and A/C hoses were in need of replacement, along with the most major repairs as you mentioned; the holding tank was already perforated on the top, and lower water tank was swimming in water in it's stringer bay.  Not sure if it was fresh or salt water, but there was already a good amount of corrosion around the fitting that connects to the other upper tank.  We didn't feel that the project of replacing the two tanks, based on cutting out the flooring to do so, was something that we wanted to tackle.
The swim platform was really in bad shape on the top, and we use ours a lot, so that was another thing that would need to be done.  Also, I didn't have a great feeling about the CAT's as a mechanic I was talking to said that replacement parts for the 3208 were getting scarce due to the retirement of those engines not long after they were installed in the boat.  The Cummins were my main choice for engines anyway, due to the better parts availability and smaller footprint.
In the bigger picture, as much as we felt this was the right cabin and cockpit layout for us, we also felt that the boat seemed to be a bit of a Rube Goldberg build, which was disappointing, as Tiara Yachts have such a great reputation.  Maybe other models had more refinement based on being manufactured for longer than the 4000 Express, but in many ways it seemed like the systems were just jammed in willy-nilly, without much thought for future serviceability.  And if you were planning on burying water and waste tanks under a beautiful teak and holly sole, why would you make them out of aluminum?  And to do that in 1998, well, let's just say I was surprised Tiara made that choice.  In my current Sea Ray, the holding tank is plastic and accessible and the water tank, while less accessible, is at least plastic.  In the end, as we are looking for our retirement boat, I don't want to battle with poor systems design and layout.
In the end, we were really disappointed that this didn't work out for us. But as much as the boat would have worked well for us in functionality, as it's often true, the "devil is in the details", and in this case it was much more than we wanted to bite off and chew up.
And if you are in the Boston area, we're practically neighbors!
(10-12-2026, 11:43 AM)August Rush Wrote: I had a 99 for a few years.  One of my favorite boats in terms of layout and seakeeping.  BUT, very slow!  In my opinion it was under powered substantially.   That said, it handled seas like a champ.
To your questions:
I too am down in the Buzzards Bay area and took a look at that boat.  We've been looking for a Cummins powered 4000 Express but I said "oh, its close by so I'll go take a look."  As soon as I saw the Cats in it and how little room there was, I said no way.  It looks like a complete PITA to work on and I do my own work.  Plus the nice thing about the Cummins is, you can do an in-frame rebuild if needed (not saying its easy but it can and has been done in these boats) and you're not cutting the boat apart.
I also found it a bit disingenuous that they list it as having had a 1000 service but it was actually done by the previous owner.  Great that is was done but don't make it sound like you did it.  Broker also said that the buyer that walked away did so because they couldn't get slip for it.  Guess that was a lie too and that you're the one who walked away based on survey.
  Delaminated hull 2003 4000 express Steve Bosse 6 1,495 10-12-2026, 03:46 PM
  2001 5200 Express knot@work 0 1,965 12-02-2025, 09:28 AM
Last Post: knot@work
  1996 Express 3500 TomReaginCarney 2 1,303 06-10-2025, 08:04 AM
Last Post: TomReaginCarney
  3500 Express Factory Option Trunk Dinghy Outboard Mount Picture JMGCINCY2023 0 902 05-18-2025, 07:50 PM
  2000 Express 35 Convert Forward Bunk to Center Queen JMGCINCY2023 2 2,716 05-10-2025, 07:33 PM
