Tiara Model Bridge Clearence Heights!
These measurements were taken by me over the years as I needed specific bridge clearances for boats I sold. I make no guarantees to these measurements and you should verify a specific vessels heights before trying to clear any bridge. These measurements do not take into account Radar or other equipment that is fixed above these measurements. Most items can be folded over if lower bridge clearance is required. The numbers listed are about as low as you can go with everything set to the lowest point. These are all the height measurements I have. I know the list is not complete, but I never had the opportunity to measure the missing models.
2900 Coronet    7'3" to top of windshield (Bimini Top Down) - 9'1" to highest point on Bimini (Top Up)
2900 Open        7'8" to top of windshield (No Arch or top) -    9'2" to top of Arch (anchor light folded down)
3100 Open        8'7" top of TV Antenna (Hard Top) - The anchor light is fixed 12" to 14" higher (suggest ratchet mount)
3200 Open        9'7" top of TV Antenna (Hard Top) - The anchor light is fixed 12" to 14" higher (suggest ratchet mount)
3500 Open        9'7" top of TV Antenna (Hard Top) - The anchor light is fixed 12" to 14" higher (suggest ratchet mount)
3600 Open        9'7" top of TV Antenna (Hard Top) - The anchor light is fixed 12" to 14" higher (suggest ratchet mount)
3800 Open      10'0" top of TV Antenna (Hard Top) - The anchor light is fixed 12" to 14" higher (suggest ratchet mount)
4200 Open      11'0" top of TV Antenna (Hard Top) - The anchor light is fixed 12" to 14" higher (suggest ratchet mount)
3600 Sovran    10'4" top of TV Antenna (Hard Top) - The anchor light is fixed 12" to 14" higher (suggest ratchet mount)
3900 Convert   16'6" top of Factory Hard Top
4300 Sovran    11'0" top of Factory Hard Top
4000 Express   10'7" top of Factory Hard Top
4400 Sovran    11'3" top of TV Antenna (Hard Top) - The anchor light is fixed 12" to 14" higher (suggest ratchet mount)
  Just purchased a 2006 Tiara 3200 new Buffalo MI Mmiklosz 0 584 11-05-2025, 11:28 AM
Last Post: Mmiklosz
  [Tiara Open] Tiara open 3000 - 2007 maxcav 2 1,755 05-25-2025, 08:25 PM
  [Tiara Open] Servicing Seacock on a Tiara 3800 open Tony Saitta 7 4,429 02-20-2023, 07:24 AM
  1978 Tiara 2500 Sport Salon - Purchase John1964 0 1,339 02-16-2023, 09:24 AM
Last Post: John1964
  [Tiara Open] Tiara Pedestal Table Legs for 38 Open ReelMagic 6 6,994 01-04-2023, 07:55 AM
