IPS steering actuator fault
Has anyone had an issue with a steering actuator overload? If so, is it a simple fix or in-depth? Thank you
(05-28-2018, 07:51 PM)Islandtime71 Wrote: Has anyone had an issue with a steering actuator overload? If so, is it a simple fix or in-depth? Thank you
IPS as in Volvo Penta’s IPS (pod) systems?!...
I’m currently dealing with an issue on one of those... It’s a VP IPS600 (VP D6 435 hp) system. The pod is turned electrically on those. The steering motor itself is fine but the “integrated” ECU (Electronic Control Unit) has developed an issue...
VP’s solution? Replace the motor with a new one. Parts are going to be somewhere around 8k [emoji35][emoji35][emoji35]
  [Tiara Sovran] Warning on EVC "Check Steering Wheel” and getting out of Limp Mode ? Donaldjames 5 5,641 09-09-2021, 01:54 PM
Last Post: Donaldjames
