Dinghy Davit Install; 4000 Express
Getting ready to install a pair of the Nautley DinghyRamps to my 4000 Express.  Question becomes one of access to the underside/inside of the swim platform (there isn't any).
There is an old set of tracks for some chocks currently on the swim platform that will be coming off.  I'm pretty sure they're screwed in from the top (no evidence someone cut the swim platform at anytime).  Is that a smart option?
I figure the other three solutions would be:
- Cut access hatches in the underside of the swim platform and reglass when done (yuck!)
- Cut access hatches in the bulkhead between the stern and swim platform (lots of unknowns)
- Attach it from the top but use some sort of anchoring device that expands once through the initial hole (like hanging a mirror at home).
Any thoughts?  How have you guys done this before?
I just went through this on my 4000 express. I recently installed the Hurley H30 davit system. I had to go through the same level of planning. At first I thought to use toggle bolts but given the weight of the tender opted to use a holesaw to gain access to the underside of the platform above the waterline. I then used the piece of material that came out as a filler and essentially re-glassed it using west systems G4 two-part Epoxy.  The Apoxsee care times is actually what took the longest. Aside from that I’d say it was a fairly easy job. Some people put deck access plates on the top side and I’ve noticed that stress cracks form so I would strongly advise against that.
As far as the gelcoat I purchased the factory match gelcoat primer and Hardner needed to complete the repair. I still have 90% of it left and would be willing to sell it to you for a reduced price. From my perspective it’ll just go to waste it’s not something that I’ll need again. Feel free to private message me if you want to talk further about this project.
(06-08-2021, 12:08 PM)MC1600 Wrote: Getting ready to install a pair of the Nautley DinghyRamps to my 4000 Express.  Question becomes one of access to the underside/inside of the swim platform (there isn't any).
Thanks August, I’m realizing that might be an option. I find it hard to believe that everyone with one of these boats and a dinghy has had to go through airing and dicing the swim platform. Ugh…
This is not something I’m going to do myself and have decided to enlist the assistance of a yard. I’ll let them know how you did it. Thanks for the offer of the extra gelcoat. I already have the kit with the factory gelcoat, so will pass that along.
The other option is to lift the deck off the same way it was originally assembled.  Its basically held in place but the rub rail, screws and sealant.
(06-09-2021, 07:19 PM)August Rush Wrote: The other option is to lift the deck off the same way it was originally assembled.  Its basically held in place but the rub rail, screws and sealant.
Oooh! Didn’t know the top came off that simple. Might be a good option. Thanks!
  1995 3500 Express LFP/Inverter Install penneyma 0 708 09-09-2026, 07:09 PM
Last Post: penneyma
  4000 Express Swim Platform Repair Jack Aperio 3 1,704 01-01-2026, 02:03 PM
Last Post: Jack Aperio
  4000 Express tender/davit install Jack Aperio 7 6,233 05-31-2025, 09:05 AM
  2000 3500 Express Hardtop Hand Rails JMGCINCY2023 0 1,843 01-30-2025, 09:22 PM
  4000 Express New Exterior Upholstery Jack Aperio 5 2,206 11-29-2024, 11:17 AM
Last Post: Richard.Janek
