Tiara Open late model 36 open
I am looking at a Cummins QSB powered 36, 380 HP each. I would like to hear from any owners about the good or bad. Is it a wet riding boat, good fuel economy etc. Thanks in advance.
Providing the engines are in good shape, you won’t be sorry with QSB’s
The Admiral and I lover our 2005 3600.  She is comfortable, roomy, very dry, stable and economical (burn is about 25 gal per hour at 26 mph if my gauges are accurate).  No regrets with our purchase.  Would caution you to check for moisture in the deck though...good luck.
(09-26-2022, 09:35 AM)jsheerin Wrote: The Admiral and I lover our 2005 3600.  She is comfortable, roomy, very dry, stable and economical (burn is about 25 gal per hour at 26 mph if my gauges are accurate).  No regrets with our purchase.  Would caution you to check for moisture in the deck though...good luck.
Thank you for the reply. I had deck problems with my Pursuit, where in particular would you be talking about?
Mine had an issue because of a poorly installed flagpole holder on the transom gunwale.  My surveyor also thought there might be some around the windlass, but I don't see any evidence of it.   I've heard of folks having trouble around the port holes.  I don't know enough about checking but maybe a good surveyor would use a meter, mine just used a hammer to test.
(09-29-2022, 10:13 AM)jsheerin Wrote: Mine had an issue because of a poorly installed flagpole holder on the transom gunwale.  My surveyor also thought there might be some around the windlass, but I don't see any evidence of it.   I've heard of folks having trouble around the port holes.  I don't know enough about checking but maybe a good surveyor would use a meter, mine just used a hammer to test.
I had to rip the foredeck off because the windlass was mounted poorly. There was a solid block between the deck up there but the windlass was only on half of it. The rest was on the balsa core, lots of coring replaced.
Attached Files Thumbnail(s)
BTW, what engines do you have? I am going to look at her this weekend.
The QSB 5.9s
(10-10-2022, 10:06 AM)jsheerin Wrote: The QSB 5.9s
The broker made a mistake, these are 425s. We are close to making a decision on this boat, it looks like it would suit our needs to a t.  I see you boat on the Sound, where about? We are over on the Peconic Bay.
We are in the Western Sound, typically from Manhasset Bay out to Northport, but have been up and down the Sound, in the Peconic, and as far as Martha's Vineyard. She's handled all our travels very well. The boat has been GREAT for us. Hope yours works out
  3500 Open deck lift piston drmiagi11 6 1,220 11-20-2026, 10:03 AM
  38 - 43' Tiara Open Comparision ClayPlatt 8 8,879 10-27-2026, 02:44 PM
  2001 3500 open, diesel exhaust flanges? North Star 4 1,667 02-24-2026, 08:55 AM
Last Post: North Star
  Tiara 34 LX (can this model be used for fishing) leid2@me.com 1 1,445 02-13-2026, 08:09 PM
Last Post: Tom Stewart
  1989 33' Tiara Open - Bedding Question jgaudet2 2 2,329 12-21-2025, 10:02 AM
Last Post: jgaudet2
