43 Tiara Sportsfisherman Forward Deck Repair
I'm on schedule to repair the softness I discovered in my forward deck and I'd like to preserve the anti skip pattern that the boat has.  I've looked into GIBCO's "molds"...but wonder if there are any other options that might be less complicated than "molding the pattern in place".  Any ideas?
Francisco
Only other option I am aware of is if you can gain access from the bottom of the deck. Cut out the wet coring and re-glass it from inside the boat.
(08-17-2023, 09:41 AM)furiarte Wrote: I'm on schedule to repair the softness I discovered in my forward deck and I'd like to preserve the anti skip pattern that the boat has.  I've looked into GIBCO's "molds"...but wonder if there are any other options that might be less complicated than "molding the pattern in place".  Any ideas?
Francisco
I went through the same thing this spring. I wasn’t thrilled about paying for the labor that my yard said would be required to match the existing non-skid. We ended up choosing to match the non-slip (Awlgrip Griptex) that covers the deck from the windshield down and around the bow cushion. It turned out great and I actually prefer it as it’s much easier on the knees when deploying or retrieving my ground tackle.
Attached Files Thumbnail(s)
I may be late on this but I had the same problem on my 30 Pursuit. They removed the deck by cutting outside the non skid, in the smooth areas and after removing the bad core used coos as coring and glassed it back down. The seams were sanded and you could not tell it was done. I have pictures if you want to see.
(09-01-2023, 07:53 AM)boatmanmark Wrote: I  may be late on this but I had the same problem on my 30 Pursuit. They removed the deck by cutting outside the non skid, in the smooth areas and after removing the bad core used coos as coring and glassed it back down. The seams were sanded and you could not tell it was done. I have pictures if you want to see.
Thanks!  That is what I decided to do in the areas were the non skid is intact.  The area where the windlass and foot switches are, I will redo with the female molds sold by Gibco.
Sounds like a great repair option! Please post pictures of how it turns out. The damage to the bow of my 4000 Express wasn’t fully realized until we started the removal process so reusing the original skin was not a viable option. I’m very happy with the Awlgrip Griptex and would love to convert the rest of the boat if I ever come across a big bucket of money.
  [Tiara Open] Cabin Laminate Repair- 3300 Open Boatworks 1 107 11-17-2026, 03:49 PM
Last Post: joshuawhite
  4000 Express Swim Platform Repair Jack Aperio 3 1,705 01-01-2026, 02:03 PM
Last Post: Jack Aperio
  Factory Tiara Classic Hardtop jmk 33 50,614 06-08-2025, 09:22 AM
Last Post: Craig Dunlop
  [Tiara Open] '86 3600 Open Cockpit Deck Hooper 2 2,187 12-10-2024, 10:57 AM
Last Post: Hooper
  4000 Express forward deck repair Jack Aperio 5 3,942 04-21-2023, 07:55 AM
