4000 Express New Exterior Upholstery
I finally got around to replacing my exterior vinyl upholstery on my 1995 4000 Express. It was all original and showing its 30 years of use. It’s not an incredibly interesting project but I thought I would share what I learned during the process.
The removal of most of the seating and back cushions is pretty straightforward. The cockpit seating is on hinges except for the engine room hatch, which is secured by six screws that are easily removed after removing the sound insulating foam from the bottom of the engine room access door. The backrest to port of that location also had three or four screws that needed to be removed from the locker directly behind. The long backrest at the stern simply lifts straight up off of a gutter/track system as does the backrest adjacent to the icemaker. The interesting part came when I tried removing the helm seat area adjacent bench seating. When trying to remove the nuts from underneath I found the bolts would spin with them. Tiara used nylon locknuts and had sawed off the end of each bolt making unthreading nearly impossible without getting access to the bolt from above. The seat cushion is over the top of them and I could not find a way to remove it. Luckily, there were decent size washers underneath that I could get a flathead screwdriver under and apply downward pressure to remove those nylon insert locknuts. This took me several hours as access is pretty tight, climbing into the small compartments to access each one. It wasn’t until I had everything removed that I noticed how Tiara managed to put this together originally. Upon closer inspection, there are six holes visible from the inside of the compartments underneath that have been filled with 3M 5200 or equivalent. These are the access points where Tiara secured the seating to the seat base with six long screws. In hindsight, simply removing the caulking and removing the screws would have allowed me to lift the seat cushion off to access the top of the bolts and would have saved me a couple hours of anguish.
The project turned out great. My upholstery guy matched “Monticello-MOT 9805” which looks to be the exact same product from 1995 although I could not confirm as Tiara did not have any record of what was used in that era. It looks original and I couldn’t be happier with the end result.
Attached Files Thumbnail(s)
Very nice. I am trying to get this done also. Thanks for posting this and commenting on the helm seat.
(11-27-2024, 09:56 PM)Richard.Janek Wrote: Very nice. I am trying to get this done also. Thanks for posting this and commenting on the helm seat.
Of course! Here are a few more pictures showing the mounting hardware. The adjustable helm seat is on a couple of slide rods that are mounted with plastic blocks. Mine were pretty brittle, so I had new ones fabricated at a local plastics shop. I also sanded the rods down with 600 grit sandpaper. You will need another pair of hands when reinstalling this setup.
Jack
Thanks again! These are very helpful photos. How does the rear bench backrest attach? Is it just supported by those brackets and you lift it up and out? Or are there screws as well? What shop did you use for the upholstery? Did you re-use the foam?
(11-28-2024, 10:52 AM)Richard.Janek Wrote: Thanks again! These are very helpful photos. How does the rear bench backrest attach? Is it just supported by those brackets and you lift it up and out? Or are there screws as well? What shop did you use for the upholstery? Did you re-use the foam?
Yes, the backrest is only attached by the brackets. No screws. Simply give it a good tug on each end and it will pop up. It is pretty snug and reinstalling requires a little pressure to get the brackets back together.
I live in Seattle, WA and used Styles Auto & Marine Upholstery in Victoria, BC. They reused the existing foam but added 1/4” layer to everything “to smooth it out”. It turned out beautifully but a few pieces required slight hinge adjustments to get the seams and edges of the adjacent cushions to align. All pretty simple stuff.
Thanks! Very nice looking boat!
  1995 3500 Express LFP/Inverter Install penneyma 0 708 09-09-2026, 07:09 PM
Last Post: penneyma
  4000 Express Swim Platform Repair Jack Aperio 3 1,705 01-01-2026, 02:03 PM
Last Post: Jack Aperio
  4000 Express tender/davit install Jack Aperio 7 6,235 05-31-2025, 09:05 AM
  2000 3500 Express Hardtop Hand Rails JMGCINCY2023 0 1,843 01-30-2025, 09:22 PM
  2000 3500 Express Adding a Drawer Freezer JMGCINCY2023 0 929 09-09-2024, 08:01 PM
