Swim platform water intrusion
Has anyone experienced water intrusion in a four foot swim platform on a 35' Express(1996)? There are stress cracks around the four D-rings mounted to the platform on the top in the corners. What is necessary for a permanent solution? Any help would be appreciated.
I have a '94 29 Open and found my platform core is wet. I've suspected it for years as the mounting bolts always showed some slight rust stains.
I pulled a few this spring and found the core is soaked. A permanent solution will vary. It may only require the surrounding area to be dug out and epoxy filled. My intention is to pull the platform in the fall, cut the skin from underneath, recore and reseal. I suspect mine is pretty wet from what I saw.
I plan on doing the same for my deck hatches. One has a lot if spider cracks and the other has a noticable soft spot.
If the work is done from the bottom you'll never notice it or even care if it's not visually perfect.
Can you attach some pic's of your problem. This would help in advising you on a possible solution.
  [Tiara Convertible] How do I repair a broken wash down/city water connection plate? Peave 4 1,686 05-12-2026, 10:18 AM
  Water alarm in the diesel filters maxcav 0 523 02-15-2026, 05:34 AM
Last Post: maxcav
  Water if forward bilge after rain lenoah 0 632 11-21-2025, 05:53 PM
Last Post: lenoah
  [Tiara Open] Water under Quartz flooring in head benmaser 0 731 06-16-2025, 02:24 PM
Last Post: benmaser
