Cummins 5.9 transmission oil cooler
I have a 32 Open with Cummins 5.9s and want to either clean or replace the transmission oil cooler. Any suggestions on possible substitute coolers or the best way to clean? I don't think these coolers were supplied by Cummins as I can't find a Cummins part #.
Thank you,
Mike Kreuser
Vero Beach
(03-26-2016, 10:11 AM)mkreuser Wrote: I have a 32 Open with Cummins 5.9s and want to either clean or replace the transmission oil cooler. Any suggestions on possible substitute coolers or the best way to clean? I don't think these coolers were supplied by Cummins as I can't find a Cummins part #.
Thank you,
Mike Kreuser
Vero Beach
I took my oil coolers, heat exchangers and after coolers to a radiator shop. They soak them in some kind of solution and pressure tested them. There is a whole maintinence procedure for coolers on Boatdiesel.com written by Tony Athens, who I consider the "man" of marine diesels. Been on that site for 3 years now and have learned a lot. Best money I have ever spent on Internet sites. His specialty are 5.9's Cummins
[-] The following 1 user Likes kurts52's post:
YOLO (03-28-2016)
Thank you,
Mike Kreuser
Vero Beach
I have used Tony's procedure to flush the entire system with great success. I did the same on all of my AC as well.
(03-27-2016, 08:12 AM)kurts52 Wrote: Boatdiesel.com
Thanks for the info and reference to Tony. I've registered at the site.  I have recently had my heat exchangers and aftercoolers removed and cleaned by a specialist. I neglected to do the oil coolers at the same time. Yesterday I removed one of the oil coolers and was able to clean it myself. Just used a hose, a piece of soft aluminum wire, and then washed thru some diluted pool acid.
MikeK
  Blown Valve Seat on a my starboard 2005 Cummins 6CTA8.3L-480CE with only 1061 hours Another Tradition 1 770 07-29-2026, 02:41 PM
  Tiara 4000 Express Cummins 6CTA 8.3 In-Frame Engine Rebuild Jack Aperio 3 2,868 05-23-2026, 03:27 PM
Last Post: Capt. Paul
  2005 Tiara 3800 ZF transmission Hemlock_SF 8 6,634 04-03-2026, 10:14 AM
Last Post: Reel Pursuit
  [Tiara Open] Cummins 6BTA 5.9 Diamond Series Engines Fishy_Business 2 1,185 12-12-2025, 12:02 PM
Last Post: Fishy_Business
  Cummins 5.9 Performance questions mggilmorern@gmail.com 8 6,807 12-12-2025, 10:26 AM
Cummins 5.9 transmission oil cooler00
