Sovran 3500
Anyone have experience on maintenance of IPS400 after coolers? I've got some dried salt build up on the inside of the front covers and someone is suggesting that Volvo suggests maintenance on them every 3-4 years. Can anyone confirm and if so an estimate of the cost of sure maintenance? Many thanks.
Tim
Tim,
I would have a Volvo Certified technition service all of the coolers on the Engines. Coolers and heat exchangers are vital to the life of your engines. A failed cooler at high RPM can lead to near instant engine failure. At cruising speed, by the time the overheat alarm goes off, engine damange may have already been done. Much less expensive to maintain the coolers and heat exchangers than to replace an engine.
My suggestion is to service coolers and heat exchangers every 3-4 years (or 500 hours, whichever occurs first) in cooler water areas (Great Lakes) and every 2-3 years (250 hours) in warm water areas (Florida, Bahamas and Carribean).
I do not have an estimate, but I'm sure a call to your local Volvo dealer will produce a timely quote.
Sincerely,
Thanks Chris. FYI, I've just received quotes to fully service the after coolers. Doing it "right" - pulling the boat and disassembling both after coolers, boiling the exchangers and reinstalling (with new seals, etc) is about $2,500 per side or $5,000 for the two. Never a dull moment with these (otherwise fabulous) IPS systems.
Best,
Tim
Tim,
Considering those engines are about $50k each, the cost for the above maintenance does not seem too bad.
Enjoy the boat!
My question is " Did the increased fuel efficiency of the IPS drives over conventional props and shafts save over $5000 in fuel?" Capt. George
Diesel engines with conventional drives still require cooler service, so the money would be spent regardless.
I have run dozens of IPS boats and hundreds of conventional inboards. IPS is definitely more fuel efficient than a conventional drive. Is it better? The answer to that is "It depends". It depends on what the owner expects, how the owner uses the boat and if the owner enjoys the quieter more fuel efficient ride. The IPS drives have to be maintained, but so do transmissions, cutlass bearings and steering systems on conventional inboard drives. The IPS drives combine the transmission, running gear, steering and exhaust into one unit.
In my experience, IPS is between 12% and 17% more fuel efficient when comparing a 40' diesel vessel. I have never run a gas IPS vessel, so I cannot comment on that. The IPS is quieter nearly vibration free. I think it's awesome running a 40' express yacht at 29 knots and getting nearly a mile to the gallon. The straight inboard counterparts generally get between .78 and .85 mpg.
So are Pod dive vessels all they are cracked up to be? The answer is "That depends". Big Grin
I like IPS for cruising vessels where comfort is the name of the game. The Sovrans are great! Fun to run and easy to dock! For fishing, I much prefer a conventional inboard with big props for positive commands when backing down on a fish. I also do not like the exhaust being mixed into water when fishing. I want to see as much as possible when fishing including into the water behind the boat.
Pods also have their limitations. Weight, beam and load are limiting factors when it comes to pod drive boats. Pods are great for relatively light low resistance boats (express boats). Heavy boat designs (Motor yachts and Sport fish Convertibles with towers) generally achieve better speed with conventional inboard gear with large props and large gear reductions in the transmissions.
Any questions?
  2000 3500 Express 6BT 5.9 Best Fuel Economy RPM's JMGCINCY2023 1 1,755 10-09-2024, 02:30 PM
  2007 3900 Sovran Owners Manual and parts manual ccomeaux 1 2,614 10-11-2022, 01:51 PM
Last Post: Euphoria38
  2009 Sovran IPS Drive Hydralic Pump Problems Opus 2 3,710 09-24-2022, 03:00 AM
Last Post: jgreenlee
  Question 36 Sovran Transmissions Kindred Spirit 3 4,633 12-18-2019, 07:56 PM
Sovran 350000
