Toilet Water
When I flush the toilet on my 2005 Tiara 2900 does the water come from the fresh water tank or from the lake or ocean water?
I believe your head, assuming its electric or manual , uses sea water (salt or fresh depending where you are) unless you have a vacuflush system and then it uses water from your fresh water tank. Easy test is to shut off your fresh water pump(s) and flush the head.
(10-07-2016, 01:48 PM)ReelMagic Wrote: I believe your head, assuming its electric or manual , uses sea water (salt or fresh depending where you are) unless you have a vacuflush system and then it uses water from your fresh water tank.  Easy test is to shut off your fresh water pump(s) and flush the head.
Thanks. It flushes without the water pump being on. So I guess that it uses raw water.
The flushing without the water only means the breaker for your head is turned on. You need to turn the breakers for the water pumps on as well. Your flush water comes from the fresh water tank unless you have a hose connected to a dockside water supply. In that case, it comes from the dockside water source.
  [Tiara Open] Cockpit Fresh and Sea Water Connectors Bob's Boat 1 875 06-20-2026, 07:16 AM
  Water tank level sensors Final Pursuit 4 2,378 10-09-2025, 06:37 AM
  2006 3600 Sovran -AC water hoses Final Pursuit 1 1,232 09-17-2025, 05:52 AM
Last Post: Splendor
  Water quick connect fittings Final Pursuit 2 1,754 07-30-2025, 03:18 PM
  2900 open - a/c water pump not running North000 2 1,685 06-22-2025, 02:18 PM
